Engine\Tranny
Old Mar 5, 2007 | 06:26 PM
W84 z-28O's Avatar
Engine\Tranny
ok this is my boyfreinds screenname. but i have a 91 camaro RS 305 TBI that smokes like a SOB my boyfriend told me i needed new piston rings because he already changed the valve seals for me and it didnt work and he told me it would be cheaper to just put in a new mottor so i wanted to know if i had to change the transmission to drop in a 350
Old Mar 5, 2007 | 06:47 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
they use the same tranny...
Old Mar 6, 2007 | 09:34 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Well while it would be easier to put a 350 in, instead of rebuilding the 305, you wouldn't want to use the same heads or throttle body setup from the 305 because it wouldn't perform well at all! I would reccommend a straight up 305 short block swap or just have your short block rebuilt!
Old Mar 6, 2007 | 11:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
W84 z-28O, welcome aboard thirdgen.org.
I could never in good conscience recommend a 305 rebuild. As stated above, the heads on your particular engine are particularly bad - fine for what the factory did, but no good for anything above that. So, if you go with a 350, get different heads as well.
The details there are involved, so it's best if you ask specific questions yourself. Whatever you do, don't just get any old 350 and assume it will work and fit - well, it can be made to fit, and it can be made to work, but how easily and how well are the questions. So, ask here first before you buy.
Even if you do get a proper 350 in there, that's not the end of the story. The computer will have to be reprogrammed, because again, it worked fine as the factory delivered it, but needs programming changes if you make changes such as exhaust and engine displacement. There's nothing fundamentally wrong with the TBI, it just needs help to work better and properly on a 350.
Old Mar 7, 2007 | 11:11 PM
W84 z-28O's Avatar
ok Five7Kid... but im new at this whole car thing and could you suggest what brand heads to use.. and how maybe to reprogram my ECM and and pretty much just help tips on getting me started
Old Mar 8, 2007 | 04:37 PM
five7kid's Avatar
If you stick with the TBI set-up, the TBI forum is a better source of information. They have stickies at the top of the forum that discuss what's needed to get a TBI engine running well, either 305 or 350.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
