Oil Pan for 400
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Oil Pan for 400
Well, after looking through the search and not finding what I am looking for, I thought I would just ask. What oil pans is everybody using that have put a 400 chevy engine in their 3rd gens? What about crossmember clearance? Anyone using an aftermarket pan and if so, what are you using? My motor has the stock pan with it but would like to go with at least a 5qt or 6qt pan, also, anyone using a windage tray in pan as well? As for stroke, this one will be a stock stroke 400. Thanks for any info and suggestions.
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
I use a Canton Racing 7qt oil pan on mine with no clearance problems. Stock exhaust won't work with it though.
Car: 82 Z-28
Engine: Built 406ci
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
