feul pump
Old Mar 10, 2007 | 01:05 PM
DillonRager's Avatar
feul pump
im dropping a 1974 350 into my 87 camaro. my in tank fuel pump on my camaro is broken so i plan to use the mechanical pump that came with the 74 motor. my question is if this pump has been sitting is it still good or should i give up the cash for a new one? thanks
Old Mar 10, 2007 | 08:03 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You need to pull the sending unit out and get rid of the electric pump if you are not using it. You can substitute some 3/8 hose in it's place or use a factory carburetor sending unit. (I found that out on this site a while ago)
You can't go wrong with a new fuel pump, in my opinion. I have had too many diaphragms rot from sitting and fill my oil pan with gasoline to trust an old one.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
