what will it make
Old Mar 12, 2007 | 09:34 PM
305blackbird's Avatar
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
what will it make
I want to start with a 350 Tpi because i have a 305 Tpi and wont have to deal with wirering. Then bore it 30 over put a 427 crank in it a high lifter cam with prob a set of port and polished toquer or elelbrock heads and top it off with the stock tpi intake and base but it port and siezmized (however u spell it) will that put out around 425 Hp or will i have to bump it up to a stelth Ram to put out those kind of numbers ? What about a carb? or a cheaper Aftermarket intake?
Old Mar 12, 2007 | 09:46 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you make absolutely no sense.. a 427 is a big block.. there is NO way you can make that crank fit in a small block.. a high lifter cam?? honestly, i've never even heard of a that.. more like a high lift cam.. you need to give alot more info on a combo that you want to know about.. cams come in infinite amount of configurations.. you also have things like compression ratios, cylinder head flow, exhaust, intake setup and flow, injectors, etc... there are WAY too many variables to consider.. this is honestly about the 10th thread i've seen like this.. what will my motor put out?? i have a 350, cam, intake and carb.. GIVE MORE INFO
Old Mar 12, 2007 | 09:54 PM
Im sorry guys I didnt even catch the 427 crank its a 400 crank a basic 383 build im realy not that stupid dont know what i was thinking ....and as for the lack of info on engine specks i basickly just wanted to know if the stock TPI intake was capable of fueling a built engine
Old Mar 12, 2007 | 10:13 PM
5678TA's Avatar
Car: 1984 Trans Am
my bad, didnt mean to sound that ****.. well from what i've heard, you would be better off upgrading or just switching to carb..
Old Mar 13, 2007 | 10:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A 350 bored 0.030" over with a 3.75" stroke crank is a 383.
Feeding a 383 with stock-based TPI is an exercise in power restriction. Getting 425 HP out of such a combo is a pipe dream, pure and simple.
Carb is by far the cheaper way to accomplish that power goal, although you give up some of the street manners of the TPI. If you want to stick with EFI, figure on Miniram, Super Ram, or Stealth Ram. The '87 TPI was the MAF system, which is a power limitation all its own. SD will be more likely to get to the power level you're talking about, but will require hardware conversion and PROM tuning.
If you want a decent-running TPI set-up, consider this http://www.sdparts.com/product/SD360...ripEngine.aspx . It will probably cost you around $6k by the time you get it on the road. It will only be 360 HP, but is a lot more realistic and pretty much guaranteed. With the route you are currently considering, by the time you get a 350, stroke it to 383, get the cam, heads, TPI, exhaust, and other modifications done, you'll probably have spent a lot more than $6k; and getting to 425 HP will cost you a lot more. As in, a lot more.
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
