V6 to LT1 Swap
Old Mar 12, 2007 | 09:34 PM
XxSgtReillyxX89's Avatar
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
V6 to LT1 Swap
Hey guys I've been searching all over TGO for a thread some one made about their swapping out their v6 for an lt1 but i can't seam to find it and I'm getting tired I've searched all yesterday and all day today and i can't find nothing all i want to know is "Can the LT1 bolt right up to the old mounts without welding or buying something new?" i wanna know if anyone has done it before too so please help me out I'm only 17 and my parents don't know about this engine thats in the garage and I'm going to UTI in September and would like to have it in by then. Cause the homecoming party is at one of the local tracks and its free drag racing all day and i don't feel like being beat by the **** box civics.
I would like to be known in my home town too cause all the import tuners are talking **** about my car.
Oh the LT1 has 350 HP 495 LBS of Torq
Old Mar 12, 2007 | 10:33 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No, it won't bolt up to the V6 mounts. You will have to purchase V8 frame mounts, move them to the front set of holes in the k-member and use a set of V8 clamshells.
Old Mar 12, 2007 | 11:06 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Will the rest of the car handle that kind of HP?
Brakes, Suspension, shockers, rad, computer, fuel pump and lotz of other stuff.
Old Mar 13, 2007 | 08:08 AM
Klortho's Avatar
Car: 1987 GTA
It's all the same, shocks and struts are the same between the two cars. Fuel pump will have to be changed to at least a TPI pump. I used a LT1 radiator/fan setup so I can't say about that. Computer will be the LT1 computer, basically, the old V6 ECM, engine wiring, motor and tranny will come out, LT1 motor, tranny, PCM and engine wiring will go in.
Old Mar 13, 2007 | 10:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You also have to change the front brake lines as they are in the way of the motor mounts.
Old Mar 13, 2007 | 12:54 PM
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
Yea i got the radiator/fan setup as well my dad just found that last night and asked about it so i lied and said my friend gave it to me which ill probably say "my friends bro went to jail for drunk driving and he gave me the motor since he had no use for it so i gave him $200". They'll believe it hopefully.
How much are the V8 mounts and clamshells? Oh whats with the maf and vat stuff that seams like its giving everyone problems when they do this swap? And i"m probably gonna put in a A/C delete kit in there as well (My A/C is the windows). How much wiring is there to be done? Whats the deal with the resister in the key, will that affect anything to do with the wiring?
(Dyno Don - "You also have to change the front brake lines as they are in the way of the motor mounts.")
Is it just the brake lines or does the whole master cylinder and booster have to be changed?
Hey guys thanks so much for your time and help. Hopefully my parents won't kill me for doing this. I think they might think I'm power hungry mostly because i do have a lead foot and they know i do. But i really do hope they think of it as a learning experience for me.
Old Mar 13, 2007 | 11:19 PM
Dyno Don's Avatar
Just the metal lines that go across.
Old Mar 14, 2007 | 09:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you're careful, you can rebend the line so it is out of the way of the engine mounts. That's what I did with mine, I doubt the metric lines would have a problem (mine is SAE).
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
