1990 v6 bird 357 swap (starter/ignition problem)
Old Mar 15, 2007 | 04:09 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
i just need too know how many wires/what wires go to the starter...
i have a small blue, and the large red (power from +) hooked up right now, but i cant seem to get it to start with the key inside...
anything else need to be hooked up? i dont know what the blue wire is, i think it leads inside the car some where...
im trying to fix someone elses wiring mistakes, so it makes this kinda frustrating and challenging....
Old Mar 15, 2007 | 07:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are a couple of wires that are spliced together in a large eye terminal that go on with the battery cable at the starter. Not sure of the color, but I think at least one is red (might be different on yours).
Old Mar 16, 2007 | 02:36 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
anyone know the colors? thanks!
Old Mar 20, 2007 | 01:21 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
Re: 1990 v6 bird 357 swap (starter/ignition problem)
ok guys, if anyone can help me id really appreciate it, i just need to know what connects to the starter, i know someone has had this problem before... i have on my first project lol, i just cant remember what i did last time....
is there a neutral safety switch on the auto trans that may cause this problem?
Old Mar 20, 2007 | 02:54 PM
five7kid's Avatar
It's on the shifter.
Did you look for the wires? Unless the harness has been hopelessly hacked, you should be able to find them coming out of the loom.
Old Mar 20, 2007 | 03:14 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
ok well theres no shifter on it right now, can i still get it started w/o the shifter?
Old Mar 20, 2007 | 03:17 PM
five7kid's Avatar
Have you hooked up that battery yet? Without the wires I mentioned, you won't have any power to the rest of the car.
You can start it without a shifter if you short the neutral safety switch wires. Be very, very sure the thing is out of gear if you do that.
Old Mar 20, 2007 | 03:46 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
yea the battery is hooked up, i havent even started on the other issues (if there is any) ...
ill find that switch and short it, im VERY sure its in P(ark)...
thanks five7, big help....
Old Mar 21, 2007 | 09:06 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
ok i shot some pics last night... maybe this will help you guys understand what im looking at here...
key on
key turned in cranking position
underdash what is this?
does this have any importance?
i was trying to show that on the floor by the kicker panel, the two yellow wires were snipped
blue wire had a white wire spliced into it?
didnt even see a NSS (What color are those wires?)
Old Mar 21, 2007 | 09:07 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
Old Mar 21, 2007 | 10:31 AM
five7kid's Avatar
Have you considered going to the junkyard and getting an unmolested harness?
Old Mar 21, 2007 | 12:21 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
no, the reason being, this car ran with the same harness and same motor previous to the motor and trans being removed for rebuilds... so im just trying to go through everything...
i guess this is one of those things i gotta figure out myself... its hard for people to respond to such a general problem... ill figure it out like i have before and post up my findings.... thanks guys... still feel free to post some comments/advice...
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gta90
Sep 15, 2015 04:00 PM
TrevinE
Sep 14, 2015 03:20 PM
