Changing to a carbed engine and stripping the engine bay.
Old Mar 17, 2007 | 02:47 PM
cubemaniac's Avatar
I'm swapping out a TPI 305 for a carbed mild 350. I wanted to strip down the engine bay to the bare essentials. My question is what all can I take out that later down the road I realise that I needed.
Oh yea forgot to mention the car is an '86 IROC
Old Mar 17, 2007 | 04:19 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the ecm harness is what to remove it is the big pass side one
other than this and the smog stuff there really isnt anything else to strip
Old Mar 18, 2007 | 01:19 AM
cubemaniac's Avatar
What all wiring do I need to keep? The engine compartment is left a mess after stripping all the TPI off.
Old Mar 18, 2007 | 01:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll want to keep the charging system, gauges, and most of the ignition wiring, probably the fans as well.
Old Mar 18, 2007 | 06:00 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
you could always just swap a factory carb engine harness in they are dirt common and were from 82 to 87 in these cars, 88 in other cars
you wont have tranny lockup wiring anymore if you pull the ecm and ecm harness
so you will have to deal with that if you have a 700r4 trans
good luck
Old Mar 20, 2007 | 09:57 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
Re: Changing to a carbed engine and stripping the engine bay.
im doing the exact same thing with my car, swappin the 305 TPI engine to a carbed, built up 350.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
