New engine overheating?
Old Apr 6, 2007 | 04:35 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Transmission: Turbo 350
Axle/Gears: Stock 2.93
Need some help...
I have an '82 TA & replaced the 305 with a 350 carb. After driving it for a little while today my radiator coolant overflow started to boil like a tea kettle! My mechanic thinks I may need another fan as the one I have on my engine now was from the 305. It's manual fan. Any ideas why this is happening?
Old Apr 6, 2007 | 11:16 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: New engine overheating?
Be really careful with your timing.
Don't you have a temp gauge? What was it reading and for how long?
Old Apr 6, 2007 | 11:28 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Before I brought my car in for a new engine install the temp gauge was working fine, now after the new engine got put in the temp gauge got disconnected somewhere along the way. So now it's not working at all? What's the ideal thermostat temp that I shoud have for my car? I've heard 140, 160?
Old Apr 7, 2007 | 09:57 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Check your air dam.
Old Apr 7, 2007 | 10:09 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
Check the air dam under the car first. If it is gone, your car is sure to overheat. Next check your thermostat, is it new with the new engine?
Originally Posted by 1320_Guy
Check your air damn.
Sorry 1320 Guy, you already told him to check the air dam.....
Old Apr 8, 2007 | 11:00 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
It happends alot when people swap a stock 305 to a mild 350. The higher hp motor needs more for it to cool right. Making the air dam more important.
Old Apr 9, 2007 | 12:55 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I agree with KrisW, check your timing. Check your radiator and make sure the fins are clean and no debries on the front.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
