V6 to327 engine swap
Old May 6, 2007 | 05:45 PM
bobbrown's Avatar
how hard would it be to swap a V6 to a 327? would the mounts lineup? it would be fine with a 700R4 trans right?
Old May 6, 2007 | 06:00 PM
Re: V6 to327 engine swap
It would be exactly as hard as any other V8 swap, as detailed in all the stickies that you no doubt have already read before posting this extremely redundant question.
Yes it will be fine with a 700; but not the one you have. You'll need a V8 one. Again, as detailed in the stickies, which were designed to prevent this question from being asked over and over like it used to be several times every day.
Old May 6, 2007 | 07:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the heads are original 327, there is about an 8 to 1 chance they won't have the accessory mount bolt holes on the end of the heads like 3rd gen V8's have. Can make accessory mounting "challenging".
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
