87 up 350 swap
Old May 7, 2007 | 12:17 PM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
87 up 350 swap
i have an 82 z28, and im looking to do a 350 swap. what im wondering is will a 87-up 350, with the one piece rear main seal fit with my tranny (an 83-86 t5) also can i use a 86 back top end? the only reason im looking at this engine is because its free. thanks for the help.
Old May 7, 2007 | 01:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only difference between a 2-piece rear main seal SBC and a 1-piece rear main seal SBC as far as the transmission is concerned is the flywheel. Get one for '86-up 3rd gen V8 and you'll be fine.
Ditto on the heads. No difference between '86-earlier and '87-later as far as the way the heads bolt to the block.
What did the engine come out of? Do you have casting #'s for the block & heads?
Old May 7, 2007 | 02:49 PM
Re: 87 up 350 swap
the heads are off of an 83-86 305. the engine is from an 88 van. so all i need for the tranny to work is a newer flywheel? are the motor mounts there, and will it accept a mechanical fuel pump?
Old May 7, 2007 | 04:01 PM
five7kid's Avatar
Your '82 mounts will work. The mechanical pump should mount up.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
