Can the engine & trans be installed together?
Old May 16, 2007 | 10:05 AM
wildstar's Avatar
Car: 1984 L69 Trans Am
I'm installing a s/b w/ a t-56 trans. Seems like it would be easier to install the engine and trans as one unit. I believe this is how they do it in the factory anyways. Was wondering if anybody has tried and what are the pitfalls?
Old May 16, 2007 | 11:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can the engine & trans be installed together?
You can, if you've got a hoist that will handle the weight of both.
Old May 16, 2007 | 11:48 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think it's easier. You'll have to tilt the tranny a lot to shoe horn it into the bay, so make sure you plug the tail so it doesn't leak fluid all over the place. Then put a jack around the tailshaft to hold the setup level, and bolt up the motor mounts. This way you can use the leverage at the tailshaft to line up the tranny crossmember bolts with the frame rails correctly.
Old May 16, 2007 | 01:32 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I would install the trans later since it is a T56. If it were an auto I would install them together.
Old May 16, 2007 | 02:52 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I would atleast bolt the clutch and bellhousing up with the motor out. Drop that in, and then install the trans last just like if you were doing a clutch swap. Then you wont have to mess with bell housing bolts and all, and you wont have to play houdini with the engine hoist trying to sneak it in... If you decide not to try putting it in all attached that is...
It can be done all together though...just takes the right heights, angles and patience.
Justin
Old May 16, 2007 | 08:41 PM
Zepher's Avatar
When we installed teh LT1 and 4L60E into the 82, we had the *** of the car up for a better angle,
We also had one of thise arms that can change the angle of the item you are hoisting,
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
