87 formula 350 to zz4 swap
Old May 28, 2007 | 10:18 PM
Mannyfr35H's Avatar
Car: 81 Elcamino
Engine: zz4
Transmission: TCI
I just purchased a 87 Formula 350 that needs a new motor and I was planning to put my zz4 motor in it. It will be backed by a TCI 700r4 with a non-lock up converter. Ive done some searches and read a few post and from what I gathered since the motor was meant to be carbed I would lose hp and the tpi setup would need to be upgraded. I am replacing the heads with the gm fastburns and have the hotcam package to go with it. I purchased a HSR to run on the motor and was wondering what I should do as far as the computer. I was planning on using the Holley Commander 950 or possibly the Accel DFI set up. I was hoping to get some input as to what would work better and which is easier to use and install. Any help would be greatly appreciated.
Old Jun 7, 2007 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Nobody else answered, and I'm probably not the best qualified.
You got the Vortec style HSR, right?
Either system should work fine. Could even use a stock computer to control it.
Old Jul 15, 2007 | 08:12 AM
imghost's Avatar
Re: 87 formula 350 to zz4 swap
Ditto that.
lt500r55
Sep 1, 2021 01:30 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Mar 9, 2017 02:35 PM
bamaboy0323
Sep 3, 2015 06:07 AM
