BBC 650hp combo ?
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
BBC 650hp combo ?
I'll start my BBC build soon and I am looking for ideas. Can someone give me a good proven budget big block combo that will get at least 650 hp.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: BBC 650hp combo ?
sorry, no BBC help here.. but i just wanted to say, your 'maro looks bitchin with that mean rake..
oh, good luck on the BBC build up..
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i just happened to be reading this months Chevy high preformance and they did a BBC VS SBC , they had a budge of 6,500 bucks for each
there BB was a 505 and made 622hp with 500 trq
was bored and stroked 4.350 x 4.250 , 10.5:1 comp
i auclt have the full listing of parts they used
which did not include the block they happened to have on hand
the small block they used was a 422 made 574 hp with 543 trq and costed the same price as the BB
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
hell i have no idea , i am to poor to afford a used 350 let alone a 454 =) i love my stinky 305 tho i just refuse to do anything proformence wise to it
Transmission: 4L80E/4L80E
Moving this from Tech to Engine Swap where most of the BBC discussions take place.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
stroke to 496.
11:1 compression
Good heads, such as 990's.
Solid roller cam, 250 @.050" and .700 lift
Team G intake 1000 cfm 4150 carb
11:1 compression
Car: 86 Berlinetta
Engine: 454 coming eventually
Transmission: TH-400
Axle/Gears: 4 link and 9" coming eventually
496 with a roller cam and a good set of heads should be able to get you there. Then you can watch your driveline scatter across the road
Scat, Eagle, and World Products all have 496 bottom end kits pretty cheap. I'll be using the forged eagle or world kit for mine. I've heard nothing but good things about AFR CNC'd heads also.
Car: 87 Z28
Engine: 383
Transmission: th350
I'll use eagle forged kit, dart 325 heads, comp cam solid roller cam, Holley 4150 carb and team G intake.
how is this combo sound?
Car: 1971 Camaro
Engine: 427
What are the cam specs?
ANd as stated, go ahead and get a good tranny, th400 or glide, and a 9" rear. Not to mention SFCs.
Last edited by Johnny Blaze; Jun 9, 2007 at 10:39 AM. Reason: Automerged Doublepost
Car: 87 Z28
Engine: 383
Transmission: th350
Car: 87 Z28
Engine: 383
Transmission: th350
Car: 87 Z28
Engine: 383
Transmission: th350
Car: 1971 Camaro
Engine: 427
Agreed.
But, 650 hp and streetability is going to be about impossible to get NA.
That combo is gonna need a 4000-5000 stall converter and 4.30 or better gears.
If you want 650 hp and good street manners its time to look at forced induction. A very mild 454 with a procharger will easily do it and be streetable.
Car: 87 Z28
Engine: 383
Transmission: th350
no need for good street manners I'll drive the car once or twice a month other than that I'll tow it to the track
thanks for the help
thanks for the help
92rsvortec350
19
Oct 9, 2015 09:39 AM
