305 tpi to 350 tbi swap
Old Jun 7, 2007 | 02:41 PM
raspyvette's Avatar
i just swaped my 305 tpi engine with a 350 engine that was only tbi now when i run the car it has alot of power when its cold but nothing when it warms up i also put on edlebrock 3" exhaust with 3" cat all oxegen sensers
in place had the car checked at local garage with an error code 45 esc.do i need to change the ecm for this motor?
i did use the top of the 305 ie.the tune port injection intake
Old Jun 7, 2007 | 03:02 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 305 tpi to 350 tbi swap
You will need to use a L98 prom in the ECM for it to work properly, also I believe the L98 ESC module and knock sensor.
Old Jun 7, 2007 | 04:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year 305 TPI?
Old Jun 10, 2007 | 02:56 PM
raspyvette's Avatar
the 305 was the origanal motor 1991 the 350 was 1990
Old Jun 10, 2007 | 09:33 PM
five7kid's Avatar
That's a "speed density" system, that needs to know what it's operating. So, it needs PROM tuning for a 350, such as the L98.
The knock sensor module is built into the ECM. I've heard conflicting stories about the knock sensor itself being different between 305 & 350.
Old Jun 11, 2007 | 12:05 PM
raspyvette's Avatar
will i need to buy a chip or can the one i have be programed or will an after market one work with the exhaust better thanks for the help pullin my hair out here
Old Jun 11, 2007 | 12:38 PM
five7kid's Avatar
Any of those options, as long as your current configuration is part of the chip choice input.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
