engine swap computer questions
Old Jun 23, 2007 | 04:23 PM
Zeikjds's Avatar
Car: 1986 Trans Am/1993 Trans Am
Engine: 305 .030 over built/ LT1 Bolt Ons
Transmission: t5/700r4
Axle/Gears: 3.43 Posi/3.23 Posi
ok i just bought a 1982 v6 firebird that has a computer controlled carb. i will be dropping a 350 in it and know i have to put new srings in it, motor mounts, etc. but what exactly do i need to do for the computer? do i need to rewire everything or what? and yes i already read for 2 hours and cant find anything.
Old Jun 23, 2007 | 04:45 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: engine swap computer questions
if you hvae to have all the emissions stuff for inspection or testing then youll have to get the harness and ecm from a v-8 car,
and the E4ME carb and computer advance controlled distributor also
the carb and distrib can come from virtually any '80 and up chevy v-8 engine that was 4bbl EST/CCC
and youll need other things from a donor 82-up carb v-8 F body such as throttle bracket and exhaust and radiator and fan/shroud and so on
if you dont have emisisons inspections or anything there then you wont need the ecm and harness or E4ME or ECM advance controlled distributor
good luck
Old Jun 24, 2007 | 02:03 AM
Zeikjds's Avatar
its 25 years old say hello to classic tags, so no emissions, i dont know if im asking this quite right, what connections will have to be rewired for the motor and it will have a carb on it, not computer controlled bs. hei distributor.
basically its gonna be a weekend warrior
383 stroker
12.5:1 CR
2.02/1.6 camel backs
1.6/1.5 rocker arms
488/510 lift cam
forged crank forged pistons
holley double pumper
3.43 posi
but ive never done a v6 swap and should i back it with a 700r4 or th350 instead of the 200c tranny
Old Jun 24, 2007 | 07:16 AM
uloozer's Avatar
Yea, I've got the same question but I would like to be able to run fuel injection from a stealth ram set up....
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
