taking block to machine shop, what should be done
Old Jul 10, 2007 | 04:40 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i have a 350 block already bored .30 over but seems to still be in great shape, i can still clearly see the honing marks. anyway i want to build a 383 with it. when i take it to the machine shop what all should i have them do? i was thinking, hot tank, bore another .10 with torque plat if needed, and install cam bearings. since its a 383 i guess i also need to get them to clerance the block unless its not something to awefully hard to do then i can. i also want to do a half block fill, is that something they need to do too or can i do it? thanxs for the help.
Old Jul 10, 2007 | 05:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: taking block to machine shop, what should be done
You can clearance it yourself with a die grinder. Don't bother filling the block, you won't need it.
italiano67
Dec 11, 2016 09:21 AM
Cameeeero
Sep 18, 2015 04:00 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
fbirdroller
Sep 2, 2015 10:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
