Engine swap
Old Jul 14, 2007 | 05:00 PM
tri power's Avatar
Engine swap
i have 1990 rs v8 camaro with 305 700r4 if i put 1976 350 and long tail trans in it i know i will have to swap the gas tank which wire on the coil do i need to put a hei distributor in it will my key still turn the engine over and will the computer affect my factory security system thanks
Old Jul 15, 2007 | 08:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why do you think you need to swap the gas tank?
The pink coil wire is the one that you would hook to a non-computer large cap coil-in-cap HEI distributor. The white wire goes to the tach terminal.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
