Biggest Valves Possible???
Old Jul 15, 2007 | 01:16 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
I am going to put LG4 heads on a 1967 Chevy 283 block. With the 283 block having a 3.875+30 over bore which is bigger than the 3.736 305 bore, what is the biggest valve I can use and still clear the bore with a large .500+ cam and 1.6 rockers? could I clear with 2.02in/1.60ex?
Old Jul 15, 2007 | 08:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's a difference between what you can do and what will do any good.
1.94"/1.60" is all that will make a difference. With a 283, 1.84"/1.50" would be fine.
Old Jul 17, 2007 | 11:39 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
Re: Biggest Valves Possible???
I have 2.02 1.60 valves on 416 5.0L heads, but I have some custom combustion chamber work in there. If you do decide on big valves, you'll need to clear the valve area of shrouding, or you'll get some pretty ineffective swirl.
Old Jul 18, 2007 | 05:38 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Yeah, but it appears your running this combo on a 350 block, unfortunately I dont have a 4.000+ bore to work with.
Old Jul 20, 2007 | 11:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You won't hit the bores. Mock it up and find out, but i'm pretty sure even with .500" lift you won't be able to get it to hit the bore.
Old Jul 20, 2007 | 11:49 AM
five7kid's Avatar
You won't hit the bores with 2.02/1.60 valves on a 305.
Still doesn't make it worthwhile.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
customblackbird
Oct 1, 2015 04:30 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
L0tuS
Sep 4, 2015 11:16 PM
