Stroking a 350
Old Jul 22, 2007 | 02:38 AM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
Stroking a 350
I know that a 350 can be stroked to a 383, but can it be stroked further then that?
Also how much horsepower & torque can be sucked out of the engine naturally aspired? No particular budget. Money & emissions are not a issue.
The current engine is a 350 out of a 92 caprice squad car. It replaced my L03 that came stock.
Old Jul 22, 2007 | 09:01 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: Stroking a 350
You can bore it 0.60 over it will be a 388 not sure how much more power.I think thats about it.
Old Jul 22, 2007 | 09:06 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: Stroking a 350
you can do a longer stroke crank 3.875 instead of a 3.75. 396ci would be the result.
Old Jul 22, 2007 | 11:25 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Stroking a 350
i have a 4" stroke, but it requires a bit more clearancing.
Old Jul 31, 2007 | 03:22 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: Stroking a 350
Money is about the only limiting factor. Okay and the necessary room to swing a 4 inch + crank. 60 over and a 3.875 crank with some 6 inch rods would be a sweet set up.
Old Jul 31, 2007 | 06:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Stroking a 350
I think it's difficult to do more than a 3.75" stroke. I think the 3.85 or 3.875" involves a lot more grinding on the oil rails, and other spots. The 4" I really didn't think is possible in a stock block. I thought you typically hit water by then. So, perhaps a short fill first?
86TA?
Also, over the 3.75" stroke, pistons are harder to find, more expensive, selection is less, and/or you need custom pistons.
It's not really a good financial decision to pay big bucks to get a long stroke crank (more $), custom pistons, etc etc, then use a junkyard 350. Might as well spend your cash on getting the 400 block in the first place, then you don't need custom parts. It'd cost less in the end, and you'd have more cubes.
Old Jul 31, 2007 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Stroking a 350
86TA?
its sitting in my garage, stock roller block and 4" stroke built by T and L engine development out of NC, warranty and everything. No fill as far as i know.
TX-SleeperC5
Feb 24, 2016 01:34 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
