picking up motor with aluminum heads
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
First off, i did search, and it seems to be broken again, so dont tell me to search.
just a quick question so i dont break something
can i pick up my engine, with trans attached by the accessory bolt holes in the heads? are they strong enough? i dont want to f-up the heads.
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Re: picking up motor with aluminum heads
Sure y not, i've done it. you of course wanna use some good strong bolts and only long enough to go through the chain and the heads. make sure there tight enough.
Car: 86 Trans Am
did you use just 2 bolts on opposite sides, or 4, 1 on each corner?
thanks
thanks
Car: 89 RS
Engine: 305 carbed
You can use just 2 on opposite corners. But for better stability i used one on all 4 corners. i used 2 equal lenght chains and connected them together in the middle with a d-shackle. then just picked everything up by the shackle.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
