Gas Cap
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
Gas Cap
I pulled my 305 out of my 82 ta and along with it, the emissions controls, among those the charcol canister. I was told if you take this out you need a vented gas cap, since this provides the venting? if this is true what is the seperate line coming from my tank and has (what looks to be) a check valve and it just hangs above the rearend? any help?
Transmission: 4L80E/4L80E
That's a relief valve. It lets excessive pressure out, not air in.
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Gas Cap
Yes you will need one. Unless you don't plug that line that went to the charcoal canister (which is foolish not to if you removed it anyway). Like five7kid said, as the fuel pump sucks fuel out of the tank, a low pressure area is generated in the tank, so in order for it to equalize in pressure (to keep your car running), you'll need to let air in some way. The vented gas cap is your answer.
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
Re: Gas Cap
I'm trying to find a vented cap (perferably a locking one) for my 82. question are all the caps 82-02 the same (threads)? becasue at my local stores they only have locking NON vented, wondering if I should tell them various years to find what I need. thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
