LT1 accessories
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
LT1 accessories
Can I use lt1 accessories from any year lt1 engine, like 93 and up? I found some accessories I wanna get but they are from a 93 lt1 camaro, and I wanna be sure they will fit on my 96 LT1 with caprice bracket
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: LT1 accessories
sure can if you use a/c you will cut the frame a bit
now if you get the acc from a vette 92-96 you are home free w/ac
Car: 83 Trans Am
Engine: LT1 350
Re: LT1 accessories
Yeah I thought about that but with the vette bracket the cost of the accessories would be rediculous, so I will stick with the caprice/fbody bracket, especially since I already have the bracket bought and on the way. I dont have any proble cutting the crossmember. Just wanted to make sure all the accessories would bolt up to the 95 bracket. thanks
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 accessories
The brackets were the same between 93-97. As far as the a/c, you don't actually have to cut the k-member, you can just use a BFH (big freaking hammer) on it where the a/c compressor would hit it to clear. I would suggest cold hammering it and not heating it up to keep the strength in the metal.
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
355tpipickup
Sep 28, 2015 05:50 PM
