454 oil lines
454 oil lines
I am putting a 454 BBC into my car... but I have a quick question about these three threaded holes near the oil filter. I tried to circle them in yellow. What do they do/hook up to? And where can I put my gauge sender? How about an oil cooler?
Thanks!
Thanks!
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: 454 oil lines
i think the one right above the filter to the left can be used for a oil pressure switch, (mechanical in my case) i dont know about the rest. on my 454 all of the holes are plugged except the ones that had things in them. also i have a question for anyone else who might know, do these need to be removed before hottanking the block? sorry dont mean to hijack
Transmission: 4L80E/4L80E
The other two are for mounting things to, such as the ball for a clutch z-link.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 oil lines
The large one is a pressure tap. Normally used for a pressure sensor. Can be used for an oil pressure source for turbo's etc. You can use it to feed an oil accumulator also. Plug it if it's not required.
The smaller hole above the filter is just a threaded hole. It's for mounting a pivot ball for mechanical clutch linkage.
The small one in the side of the block should go into a coolant gallery but may also be a blind hole. A temperature sensor or knock sensor would normally go there. You can put a drain tap in there to help drain the block but it's above the frost plugs so it wouldn't drain very much.
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
