how hard of a swap is the ls1
Old Sep 3, 2007 | 09:40 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
how hard is the ls1 to swap in? i have replaced a 305, it was a pain but not to bad. is it alot harder to get the motor to fit? 383 vs ls1 price and long term engine lasting is a concern.
Old Sep 4, 2007 | 06:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how hard of a swap is the ls1
the 383 will bolt right in and use all your factory accessories, engine mounts wiring ect.
the ls1 will require aftermarket motor mounts, maybe a k-member, different trans, trans crossmember, you probably cant use any of you accessories, you have to re-do all the wiring and use the harness from a 4th gen f-body.
Its a LOT more work, but they results can be very impressive, if you have the knowledge to complete the job.
Old Sep 4, 2007 | 09:19 PM
Diabloformula's Avatar
I'm finishing mine up this weekend, been working on it for the past 3-4 weeks off and on, it is alot of work, but I would have to say more time consuming then anything else, also you can make a stock LS1 with heads and cam or even just the right cam and boltons out perform a 383 and you'll still get 25 MPG Highway, let's see that 383 do that, I also have a 98 Formula LS1 and love it!!!! All in all when you look at it, it's all just a bunch of nuts and bolts.
Old Sep 5, 2007 | 10:37 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You don't have to swap the k-member, you can bolt a 700R4 up but 4L60E is a better choice or 6-speed (don't have to swap the tranny crossmember with an automatic, only the 6-speed) There isn't alot of wiring that needs to be done, around 8-12 wires total to hook up and will have as much HP as a 383, and with a cam more power and like diablo said, 25-29mpg on the highway.
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
86White_T/A305
Aug 17, 2015 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
