1LE Serpentine system fasteners
Old Sep 3, 2007 | 10:32 PM
bladerunnerss's Avatar
There isn't a complete fastener kit for the entire 1LE serp system is there. crank/w.p. pulleys, both brackets to block, AC to bracket, Alt to bracket etc. I have the psp to bracket fasteners.
Just wondering... I cant seem to find mine, but am confident they will show up when I re-org the garage. But if they dont this whole system is usless to me.
Or if anyone can spell out the thread pitch/dia/length/shank etc and quantity of each (asking alot i know) Ill just hunt em down on my own.
and one other question. I read through all the "how to eliminate smog pump" write ups. It seems that it is published that one needs to use a 96.8 inch belt. In a thread post dating that write up there was complaints that the mentioned belt was too short or too long (cant remember). Can someone spell out what size belt to use routing the serp like this?
TIA
Jason
Old Sep 4, 2007 | 10:55 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: 1LE Serpentine system fasteners
just mesure the depth of the hole on the block and whats needed in the accesoriess round it down (shorter) and go get some 3/8 corse thread grade 8 hex bolts from the local hardware store to mount it all up dont forget washers this is what i did
for the belt it can be rerouted to work might be just a hair to loose if old and worn
Galaxie500XL
Feb 1, 2020 04:53 AM
Bohemian
Aug 15, 2017 05:11 PM
PurelyPMD
May 5, 2016 04:57 PM
codeysabatini
Nov 10, 2015 04:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
