LT1 engine mounts
Old Sep 9, 2007 | 07:41 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
LT1 engine mounts
Can anyone tell me why LT1 complete engine mounts are so damned expensive? I checked and Advance wants $240 each, so basically $500 per set. What the hell makes them so special that they ask for so much?
Cant I just use the mounts that are in the car(305)since they are both sbc engines? I was wanting to go aftermarket, but it appears that all the aftermarket engine mounts are only the insert kits, and not the actual mount assembly.
What would be my best option. I was thiking either using poly mounts or solid mounts. Not sure which way to go? Its not a daily driver, but I'd definitely want to maintain some comfort. How bad would the vibrations get with a solid mount?
Old Sep 9, 2007 | 07:54 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 engine mounts
Don't use the LT1 mounts, you can use the clamshells off of the 305 that came out of the car.
Old Sep 9, 2007 | 08:24 PM
ssean92's Avatar
Car: sold
I second that
Old Sep 9, 2007 | 11:52 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
So I can just use the mounts already in the car, and bolt right onto the LT1, and buy aftermarket poly mounts for the 305? That would be great. It would certainly save me a TON of cash.
Old Sep 10, 2007 | 07:21 AM
ssean92's Avatar
Car: sold
yes that is it
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
