FOUND LT4 with hotcam
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
My friends dad wrecked a lt4 vette. Its 2 states away. I want to put it in my firebird. Do i Need to bring the block home or is it the same as a 350 tpi.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: FOUND LT4 with hotcam
the LT4 is a different manifold then your TPI, different coolant routing, and distributor is mounted off timing cover. yes that would be a great swap for your bird. do some searches for the swaps that others have done here for your specific needs.
Transmission: 4L80E/4L80E
You should get the entire engine, ECM, harnessing, and all accessories. The blocks are different - mounting an LT4 induction on a TPI engine, although it can be done, is just silliness (IMHO).
You will need to change the oil pan and oil pump to f-body style. The engine mounts from the TPI engine can be used on the LT4.
Engine: l98 350 tpi
OK, thanks that helps. I Hope i can get the motor out in one day. Ill get a few friends to help.illl have to come back another time to pick it up in a truck. I dont think it will fit in my taurus.
The car has been sitting for 5 years. He had some stuff done to it but im not sure what. Il find out! Ill post some pics when im done. I put a ram air hood and a pearl paint job on it. I just need it to be a liittle fast than a 14.3. Mybe in the 12s with the lt4.
Car: 2001 tarus/ and 84 TA
Engine: 408 sb
Transmission: 2 speed powereglide
Axle/Gears: stock:(
if its been sitting for a few years it might be a good idea to prime the engine. and while you have it out its a prime time for header instalation..... you might want that extra flow with that cam.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
But either way, Five7 is right... you want to get the ECM, wiring harness, accessories etc. as well as the engine itself. And you'll need the whole engine. Its a totally different block casting from the TPI engine. TPIs are just tradiational SBC, but the LT1 and LT4 are not - they only (sorta) look like it.
rudolphschenker
Sep 4, 2015 02:41 AM
