LT1 ?
Old Sep 29, 2007 | 01:36 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
LT1 ?
Would I be able to take an LT1 out of an Fbody and put the corvette acessory brackets on it to use the vette routing?
Old Sep 29, 2007 | 06:27 PM
BCdawg57's Avatar
Re: LT1 ?
And are the wiring harnesses interchangeable from any of the years?
ECM's?
Old Sep 29, 2007 | 06:40 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 ?
You can use the vette brackets, but purchasing them are expensive plus you will have to use the PS pump, AC compressor and alternator from a vette as well. Best thing to do is use the complete F-body setup, wiring, PCM and accessory setup.
Old Sep 29, 2007 | 09:42 PM
BCdawg57's Avatar
Re: LT1 ?
Are there any years where you can interchange the wiring harness?
For example, using a '94 harness on a '95 engine?
Jake
Old Sep 30, 2007 | 10:07 AM
Klortho's Avatar
Car: 1987 GTA
Re: LT1 ?
you can use a '95 harness on a '96-'97 engine, but not a '96-'97 harness on a '94-95 engine without swapping things like the timing cover and opti pigtail for the '94.
Old Sep 30, 2007 | 11:20 PM
BCdawg57's Avatar
Re: LT1 ?
Ok, thanks just what i needed to know.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
