305 to 383 swap.
Old Sep 25, 2007 | 12:46 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
305 to 383 swap.
howdy all.
im planning on doing a 383 swap this winter on my 1990 305 RS.
got the tranny and everything for the added power of the motor.
i just need help with the fuel lines.
will the stock fuel lines work or will i need bigger ones?
i hear to big of fuel lines isnt good. but i dont know.
and i know i may blow the rear end of my car. i also was wonder. what is a good rear end to get?
i keep hearing the 4th gen posi rear ends are good.
i want something strong that wont break.
im wanting to do at least 12s or better on the drag strip.
Old Sep 25, 2007 | 12:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 383 swap.
Stock fuel lines will be fine.
Old Sep 25, 2007 | 01:22 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
9" or 12 bolt rear although very expensive are great rears... or read the tech article on how to beef up a 10 bolt. Stock you will be lucky to last on the strip with good traction.(dont forget LCARBs)
Old Oct 1, 2007 | 09:06 PM
ChevyRS-305's Avatar
i know where you can get a ford 9" rear out of an old ford pickup but u may want to sandblast it and change the gears out. plus a disk break conversion kit and bracket kit so you can mount that dang thing. thats what i did with my drift car.
Old Oct 1, 2007 | 09:09 PM
joshh44's Avatar
Engine: engineless
where could i get this 9inch??
and for how much???
mhatfield 14
Oct 24, 2015 07:48 AM
5spdcamaro
Aug 28, 2015 02:12 AM
bdads
Aug 24, 2015 06:01 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
