V6 to V8 engine swap
Old Oct 4, 2007 | 06:20 PM
92RTripleS's Avatar
Car: 92 RS Convertible
Engine: 383
Transmission: 700R4 Streetfighter
Axle/Gears: 3.73 posi
i have a 92 rs with a v6 and im trying to swap in an 88 iroz 350 with tpi. im having difficulty with the wiring harness and i was wondering if it would just be easier to buy a new harness. i have the old one off of the 88, but the pins dont match and its in kind of rough shape.
is there a factory wiring harness i could buy that would match with the one inside the car, or am i going to have to get one of those as well? im also curious as to what other problems i might run into as well.
Old Oct 8, 2007 | 12:26 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Re: V6 to V8 engine swap
The easiest thing to do would be to find a wiring harness from a TPI car. Going from a V6 to V8 EFI car I would think would be about impossible. You have more injectors, the sensor's are in different places.
You can buy a harness from painless or somewhere like that but would be just as good to watch the for sale board and get a harness from a wrecked car or someone who is going to carb. Good luck.
Old Oct 8, 2007 | 08:23 PM
92RTripleS's Avatar
Engine: 383
ok thanks. should i get one for an 88 TPI car since all the TPI stuff i got was from an 88 even though the car i have now is a 92? I was curious what i was going to have to go with the interior wiring harness too. Am i going to have to switch that one out too, or can i just switch the pins on the connects to match that of an 88?
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
