will i need a new hood
Old Oct 9, 2007 | 02:25 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
if i swap out my 3.1 v6 to a 350 will i need a new hood
Old Oct 9, 2007 | 07:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: will i need a new hod
no, unless you are running a very high induction system.
Old Oct 9, 2007 | 07:43 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Are you planning on staying with fuel injection or converting to a carbed 350? I was wondering the same when I swapped a 350 but I found out how to get around.
Old Oct 9, 2007 | 08:30 PM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
im going to carb 350, did u have any problems steven?
Old Oct 10, 2007 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In order to shut the hood, a drop-base air filter was required in my case.
JamesC
Old Oct 10, 2007 | 09:28 AM
I have an edelbrock performer rpm, and a holley 600 vs, and the stock TBI air cleaner, I'm hoping that will make it, otherwise back to the drawing board
Oh and sorry for stealing your thread thebird91
Old Oct 10, 2007 | 05:37 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
If money isnt too tight, I would suggest getting an edelbrock carb. Getting the carb allows you to not need the unnecessary spacer from edelbrock to holley. Edelbrock, (like said earlier) does indeed make an air cleaner for hood clearance! The part number is 1206 I believe, drops 1.5' below carb
To answer an earlier question, yes without the low profile air cleaner I would have needed another hood
Old Oct 15, 2007 | 11:10 AM
racerd146's Avatar
Car: 92 firebird
im doing the same thing thinking of doing a carbed turbo 350 with the pressure plenum would i need a new hood?
Old Oct 15, 2007 | 01:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure how you come up with that, since both the Performer and typical Holley are squarebore. The originator hasn't come back, but the typical Performer-type stock replacement intake manifold has the mounting provision for either the squarebore Holley/Edelbrock, or spreadbore q-jet.
For me, money is always too tight to get an Edelbrock carb. It's also too tight to get a vacuum secondary Holley.
Old Oct 15, 2007 | 08:14 PM
my holley bolted up fine to the performer rpm (thank God, and five7kid)
Old Oct 15, 2007 | 09:20 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I think some people on here have a turbo hood? I dont know much about it.
Hmmm, I have tried to bolt up Edelbrock to Holley and bolt holes for me didnt seem to line up correctly.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
