Engine Swap 92 Buick LeSabre 5.7L to 86 Z28 Camaro 5.0L
Old Oct 13, 2007 | 10:07 PM
RElias0903's Avatar
Car: `86 Z28 Camaro
Engine: 305- 5.0L
The car with the 350 motor is either a LeSabre or a roadmaster. Will this engine fit well or will modifications need to be made? Also if transmission is switched should it work with the rest of the original chevrolet parts in the camaro?
Also will the engine run differently than if I use a rebuilt chevrolet 5.7L?
Old Oct 13, 2007 | 10:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They are basically the same engine externally.
The transmission will be missing the torque arm mount on the tailshaft housing. 4 bolts, switch them around.
Old Oct 13, 2007 | 10:50 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Engine Swap 92 Buick LeSabre 5.7L to 86 Z28 Camaro 5.0L
Woa, I thought someone was putting a 350 into a LeSabre.....
Yeah the 350 from the Roadmaster would bolt exactly where your 305 was. But I would think that you would need the computer from the roadmaster also, for the 350 throttle body injection, unless you plan on putting a carb on it. I would think that the Roadmaster computer can plug right into where your existing computer is tho.
Old Oct 14, 2007 | 04:55 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The longblock is pretty much "plug and play", however the center intake manifold bolts are angled differently, which will require you to modifiy those bolt holes in the intake (assuming you are keeping your original intake).
Old Oct 15, 2007 | 08:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
LT1 or TBI 5.7???
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
theshackle
Mar 5, 2017 06:37 PM
reiderz iroc
Aug 13, 2015 04:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
