Wiring Suggestions
Old Oct 15, 2007 | 06:50 PM
TeknoMaeg's Avatar
Wiring Suggestions
Well the diagrams I have are pretty much useless.
I recently (yesterday) ripped out the stock 305 (carb) and dropped in a built 396 small block.
It's from the stone age but is far more potent than the OEM anvil that was in there...
My question is what are the best diagrams? I need to convert the harness to run this engine by friday... I am about to just rip it all out and start from scratch, but I still need to know what to keep to have the guages function.
Old Oct 15, 2007 | 09:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, since you labeled everything as you disassembled the stock engine for removal, you need the alternator wiring, the engine coolant temperature sender in the driver's side head, the engine cooling fan switch in the passenger side head, the power and tach wires that went to the coil, and the oil pressure sending unit wire. Depending upon what you are doing for the fuel system, you may need the oil pressure switch as well.
jklein337
Sep 19, 2018 06:23 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
InfinityShade
Aug 22, 2015 08:00 PM
djmarch
Aug 9, 2015 05:27 PM
