putting a 350 in camaro
Old Oct 22, 2007 | 08:39 PM
kittycannon's Avatar
Hey i am just wondering, would a 350 four bolt engine fit in my 1985 camaro, the casting numbers are 3970010,if you could answer this post as soon as possible id be grateful
Old Oct 22, 2007 | 09:00 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
Re: putting a 350 in camaro
yes sir why wouldnt it fit?
u have a 305?
Old Oct 22, 2007 | 09:01 PM
no, i have the 85 with the v6 2.8, thats why i need to replace it
Old Oct 22, 2007 | 09:07 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Any engine will fit into any car depending on how much time and money you want to put into it
There are like literally hundreds of threads on here about putting a SBC into an F-body
Old Oct 22, 2007 | 09:31 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
simple non-sarcastic answer: Yes. a 350 will fit easily
the only problem you may have is with trying to use any of the old V6 stuff, which i dont think any of it is compatible, and i think the transmission MAY need swapped too but im not sure. Still, it should be a relatively painless swap.
Last edited by LMSkyliner; Oct 23, 2007 at 06:53 AM. Reason: miss-typed alot of stuff lol
Old Oct 22, 2007 | 11:13 PM
1990_RS350's Avatar
Yeah it'll fit but like the guy said above me, i'm not all that sure but i also think that the tranny would have to be swapped out. and i've heard that doing the conversion from a v6 to a v8 you'll have to change out quite a bit of stuff, namely the motor mounts.
Old Oct 23, 2007 | 12:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Read the sticky in the top section of this forum about V6 to V8 swaps.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
