motor swap
Old Oct 24, 2007 | 04:20 PM
3genLT-1's Avatar
motor swap
i am trying to swap a carburated 95 LT1 into a 91 z28 what can i look forward to in problems and in cost.
Old Oct 24, 2007 | 05:22 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: motor swap
Problem and cost = carb on LT1 do yourself a favor keep it fi.
Old Oct 24, 2007 | 07:06 PM
3genLT-1's Avatar
Re: motor swap
im kinda set in what im doing i want the low end torque that a carb produces. i heard that a new radaitor will be needed cause of the reverse flow and a new fuel pump or regulator to lower the fuel pressure? im trying to confrim this before i start.
Old Oct 24, 2007 | 07:30 PM
JPMZ28's Avatar
Re: motor swap
you will need the check valve in the heater hose to keep it cool. I would have to say FI is the way to go too.If it was me it would be a LS1 or the L98, LT1 im not a big fan.Would like to see pics when you done. good luck.
Old Oct 24, 2007 | 11:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
More torque with carb?
Don't think so.
Old Oct 28, 2007 | 09:28 AM
Car: 1992 camaro
Axle/Gears: 3:73
Re: motor swap
check out www.camaroZ28.com there is a few guys over there that have done it. They can help you out.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
