OLDS 455 INTO 1989 CAMARO???
Old Oct 25, 2007 | 05:25 AM
PETERBILT-359's Avatar
HELLO- CAN ANYONE HELP ME WITH THIS SWAP? I WAS WONDERING WHAT IS INVOLVED IN TAKING OUT A 305 AND PUTTING A BB 455 OLDS IN. ANY HELP WOULD BE GREATLY APPRECIATED.. JOHN
Old Oct 25, 2007 | 08:13 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: OLDS 455 INTO 1989 CAMARO???
About the same as dropping a Buick, Pontiac or Caddy engine in. There is no direct swap kit available so some fabrication and modifications are required. The transmission needs to be changed because the bellhousing bolt pattern is different.
Easiest swap is a BBC.
Old Oct 25, 2007 | 03:39 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You should really search the engine swap forum. Myself and others have put Olds motors in these cars before. Pretty much all of your questions will be answered.
Old Oct 27, 2007 | 06:06 AM
THANK YOU FOR YOUR REPLYS. I WILL KEEP CHECKING. DOES ANYONE KNOW WHAT HEADERS MIGHT WORK?? THANKS AGAIN JHN
Old Oct 27, 2007 | 08:57 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
You have to make them.
I used ported big block manifolds...
Old Oct 27, 2007 | 10:34 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Other than SBC and BBC swaps into a third gen, any other engine requires custom made headers.
Old Nov 2, 2007 | 11:22 PM
425rocket's Avatar
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old Nov 2, 2007 | 11:30 PM
425rocket's Avatar
search the forum for "Dropping an Olds. 455 in my '86 Firebird" it was very helpful to me. I'm also dropping in an olds, but a 1965 425 super rocket the ultra high compression version. and don't thank me "five7kid" helped me just today. im knew here so just tryin to help. this place seems friendly and helpful and i dont want to be a sourpuss around here. hope it helps!! LET THE BIG DOGS(blocks) EAT!!!
Old Nov 3, 2007 | 10:46 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
When you search, keep it simple...
Go to the engine swap forum and search just for the word olds, you will then have a great place to start!
Good luck!!
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
