89 V6 to 350 wiring
Old Oct 29, 2007 | 08:15 PM
fastregalwe2's Avatar
89 V6 to 350 wiring
The original owner was a f**ktard and screwed up a bunch of stuff on this car.
He cut the wring harness in several places.
To try and keep it fairly clean and simple under the hood, can I use an 82-86 carbed wiring harness in place on the one I pulled out?
Otherwise, I will prolly opt for a Pianless harness.
TIA
Old Oct 29, 2007 | 09:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What are you putting in with the 350?
If you go with an old-school carb, you'll probably find that what you need is still available.
Old Oct 29, 2007 | 10:09 PM
Re: 89 V6 to 350 wiring
Yes, its getting a carb
Old Oct 29, 2007 | 11:22 PM
five7kid's Avatar
You'll need coil power wire, tach wire, alternator wiring, gage wiring (oil pressure, engine temp). That stuff comes from the driver's side of the engine compartment.
Any idea what was chopped, and what's still there?
Old Oct 30, 2007 | 06:39 PM
All the wiring from the firewall bulkhead connector was still there. What he cut came from the ECM side and was near the core support and looked like it went from the right side over to the front near the center of the radiator.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro11j
Sep 19, 2018 08:49 AM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
