pulley question
Old Nov 27, 2007 | 09:05 AM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
pulley question
im swapping from V-6 to a 350 about to get the motor built but i was trying to decide what belt system to use i came across these and wanted to know if anyone has used them?
Im not gonna have power steering so i thought this would be great, any input would be appreciated.
http://www.blackmountainprecision.com/sb5.htm
Old Nov 27, 2007 | 06:11 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: pulley question
does this even look like a good setup or is there anyone who wouldnt recomend this kinda belt?
Old Nov 27, 2007 | 06:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: pulley question
more for show, unnecessary, but it should work fine.
Old Nov 27, 2007 | 07:16 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: pulley question
it should be stronger than a regular serpentine system huh? having the grooves instead of a regular belt?
or less slip in some case?
Old Nov 27, 2007 | 08:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It'll be fine as long as you don't care about things like power steering, air conditioning, or emissions.
Factory systems aren't that hard to come by.
Old Nov 27, 2007 | 09:27 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
Re: pulley question
i saw a big block first gen with those pullies and thought they looked sweet, now i know where the guy got them!
Old Nov 27, 2007 | 09:45 PM
autotec101's Avatar
Car: 86 bird
Transmission: 5 spd
Re: pulley question
on my v6 to 350 swap I ordered these http://www.marchperformance.com/
Old Nov 28, 2007 | 05:20 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: pulley question
the reason i wanted the other ones cause there not as expensive and in my opinion still look good, im not going to have power steering, ac, or emissions, so i thought these would be perfect....thanks for the input!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 12, 2015 11:33 AM
