Custom Fuel tanks?
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Custom Fuel tanks?
does anyone make a third gen tank that has a -8 return a -6or-8 rollover valve, stock fuel fill point, with a sump and two -10s or -12 outs? thanks
I didnt know where else to put this.
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Re: Custom Fuel tanks?
Not for a stock tank. (that I know of)
I put a RJC allum. cell in the back of my car. It's -8 feed -8 return -6 roll over with check ball. 15gallon.
This fits in that deep part under the hatch. I built a allum. hatch cover that has black carpet on it. It's NHRA safe and looks nice.
Stock tanks just don't cut it for very long when your using a boosted engine.
(Turbo buick in mine) you've got a sbc with turbo setup. I understand your fuel needs.
I run a fitting right on the cell that converts it from -8 to -10 then to the aeromoive pump then to the fuel rail. I can run -6 back to the tank. No problems there.
I can take some pictures of my setup and post them if your interested.
~Scott
~Scott
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Darn digital camera batteries were dead..> I'll snap some pictures tomorrow morning and post them. Columbus OH? If so That's one of my favorite tracks
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Here's my cell and cover. The 15gal like I have in mine needs the front corners to be square to fit in there real good but I like the big tank.
A 10 gallon fits right in.
Here's pic's of the cover I made out of thick allum. and covered it with black carpet.
Hope that helps you.
~Scott
~Scott
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
That is the way it is designed. RJC makes a 15 gallon (Pictured) and a 10gallon.
The 10gallon fits right down in there. The 15gal needs to have the front corners of the unibody modified to fit down in better. (like mine)
RJC Racing makes plastic and allum cells. Either are fine.
Hope that helps,
Scott~
Hope that helps,
Scott~
Car: 85 camaro z28
Transmission: auto to manaul
looks great. how hard was it to intall and the lines? could you use the stock lings any way?
lines*
lines*
Here is one that fits! http://www.nastyperformance.com/93-97F-Body.html
Neil put one in his third gen here! Scroll down to post #1111 https://www.thirdgen.org/forums/body...te-now-23.html
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
The stock lines are too small supporting any kind of power. I run a -10 feed and -6 return to the tank. Aeromotive A1100pump.
The RJC Cell is under 200.00 and the Aeromotive pump is under 200.00 as well.
~Scott
~Scott
briging up this old thread, but i would like to know with that fuel cell the one thats down in the trunk space, can u smell fumes? i would like to get a cell simular to that but my car is gona be my daily driver and i dont wanna smell fumes all day long, your help is appricated
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
I drive my car daily in the summer as well.... The red color line that's at the top of the tank there is a vent line.... all the fumes go out that line. You could connect it to the factory charchol cansister if you've still got it but I just have it venting there under the car. No fuel smell in the vehicle. The tank has a anti roll over check ball on that "vent" line built right into the tank.
RJC is the maker of the tank.
Hope that helps,
Scott~
Hope that helps,
Scott~
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Hope that helps,
Scott~
Hope that helps,
Scott~
It's not listed on the RJC racing site.
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Oh Man guys.... I totaly goofed.... it's RCI not RJC... I'm a idiot.
Look at summit racing and enter RCI and look under fuel cells. THere's alot of stand up cells like the one in mine.
RJC Sells all the products for the Turbo Buick guys. I'm so usto saying and I guess typing RJC that I just put it down. I'm sorry for mis-leading you on the name brand....
Check out RCI (duh) LOL..
Good luck fellas.
Scott~
Good luck fellas.
Scott~
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
