89 IROC TPI into 91 firebird - air intake ?
Old Dec 6, 2007 | 06:35 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Will the IROC air intake fit under to 91 firebird hood around the hood latch area? Hood close?
Or will I need the Firebird air intake?
Finally getting around to doing the swap.
EDIT: I wasn't clear on what I am doing - the engine is a TPI 350 from a 1989 IROC. Going into a 1991 Firebird. It is not a Formula or Trans am.
Using the 5-speed from the 305 TBI. Using the 3.23 posi rear w/disc brakes. WOuld like to use the 700r4 but too much stuff to change out right now.
Last edited by FNFAL308; Dec 6, 2007 at 09:27 PM. Reason: To clear up a question in another post - may be needed here also
Old Dec 6, 2007 | 06:51 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 89 IROC TPI into 91 firebird - air intake ?
You need the firebird intake stuff...
1992 Trans Am
May 10, 2023 07:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
