Swap suggestions
Car: 1987 Camaro
Engine: 5.7
Swap suggestions
Ive got a small block 350 and heads out of a 77 el camino, looking to do it as an lg4 build with this block, gonna be done as a budget build, meaning a little at a time, what do you suggest as a start for this, what cam and so on?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Swap suggestions
I suggest starting with some cylinder heads that are actually worth a damn. Yuo should keep the LG4 heads from your 305, that's a great start. The next thing is to get a retrofit roller kit for your engine with those aftermarket lifters that have the link bars on them.
From there, it's up to your budget...
theshackle
Mar 5, 2017 06:37 PM
