budget buildup
Old Dec 11, 2007 | 11:29 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
budget buildup
Whats up guys i'm trying to build a motor as efficiently and the most cost effective way i can. I've been looking at motors around 400hp and i've found some nice crate motors on ebay for around $3500 turn key assembly. Mostly 383 strokers and a few 350s. Is that the cheapest i could probably do that will give me some type of warranty? Summit is horrible pricing motors for $6500 screw that.. There are also some verrry cheap 700r4s stage 2 (550hp) on ebay backed with a 1 year warranty for only $750 w/ free shipping. So with the mods i have to do to gut out tbi and switch to carb im guessing i need $6000 to do everthing right. any input?
Is building a motor relatively that much cheaper?
Old Dec 11, 2007 | 11:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The biggest advantage of building it yourself is being able to choose exactly what goes into the package.
Not far behind is knowing it was done right. There's a member who has been documenting his woes on the Tech forum who just found out his 383 was put back together (for the 3rd time, if memory serves) with a broken piston.
I always say figure on spending as much money supporting the power as you spend on making it. Tranny is a big part of that, including torque converter.
Old Dec 11, 2007 | 01:28 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: budget buildup
Whew! Boy, I guess everybody has a different idea of what the term "budget build" means!
Budget build in your needs (400 hp) means this to me:
350 short block, 1987 and up, roller cam, rebuilt by me with forged pistons, pm or used rods (performance type), LT4 hotcam (used, most likely) and a good roller type timing chain. Stock Z28 style oil pump.
Vortec heads, freshened up with a valve job and some high lift springs with guides cut down for high lift OR 305 LG4 or TPI heads with the same mods
Performer RPM intake with 750 cfm TBI unit (probably from eBay) and in tank vortech fuel pump.
Used Laptop to run the tuner Pro stuff that the DIY PROM guys use to tune the setup.
The only thing worth paying full price for (as far as I'm concerned; some people love new stuff) are the 1 3/4 headers that Dyno don sells on this site. I like the SLP's if you can get them used but they're hard to find.
Starting with this engine will save all of the machine work to the bottom end and provide the heads with only the valve guides to be cut and high lift springs installed.
http://www.sdparts.com/product/12530...er8500GVW.aspx
I would only replace the cam with an LT4 hot cam and put forged pistons (if that) in it and then bolt on my intake and exhaust.
You will think you bought a new car. On a budget...
cheesehomer
Dec 31, 2015 08:48 AM
Jorlain
Oct 8, 2015 01:57 AM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
