wireing for starter
Old Dec 15, 2007 | 10:19 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
wireing for starter
What color is the starter silinoid wire on a 3.1 in a 92 .. I am swapping out a 3.1 to a 350 but i didn't take the motor out to label anything I found the altinator wires They were different but found them found the starter wires I have a purple wire i think is the starter silinoid wire but the starter doesn't work with it so wondering is it the wrong wire or is there something else wrong
Old Dec 15, 2007 | 01:52 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: wireing for starter
Purple is the wire. There is a "starter enable" relay that must get turned on by the ECM via the VATS or PASS-key decoder module. You will most likely have to find that and by-pass it.
If you search you will find lots of VATS by-pass information.
I typically would just jumper the starter enable relay out. It has a yellow wire on one side and a dark green on the other. As long as you are running a carb engine with an older HEI distributor that will do the trick.
Old Dec 15, 2007 | 06:19 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Any Idea where the starter enable relay would be
Under the hood or under the dash
Old Dec 15, 2007 | 10:20 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Found the issue a group of ground wires and the ecm Fuse
Cranks now
trans lines timing plugs and wires and fuel lines and hopefully it starts it's an 84 truck 5.7 with an Edelbrock intake carb and a comp cams 300 duration 500 lift cam should rumble pretty good with shorty headers
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
L98GTA87
Aug 5, 2015 11:02 PM
