swapping motors (electrical)
Old Dec 19, 2007 | 10:28 AM
kritr415's Avatar
Ok so i bought a 1988 iroc z shell from a friend. it is set up for a tpi motor and i already dropped a carb 350 in it. is there a wire harness or an easier way to hook it up so it will run and my guages will be accurate?
Old Dec 19, 2007 | 05:10 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Re: swapping motors (electrical)
you can just buy sending units to fit that year car and they should work on the 350 just fine. i don't know of an easy button fix though.
Old Dec 19, 2007 | 09:50 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
The gauges don't run off the ECM; you should be able to use the stock sending units for a TPI V8. You still need the fat Pink wire that goes to your coil harness. That wire will go to your HEI BAT terminal.
You need to find your start wire and you'll be set. It's usually purple.
Jorlain
Aug 24, 2022 05:11 PM
TheExaminer
Aug 19, 2015 10:07 PM
355sbcTPI
Aug 19, 2015 04:38 PM
st.evel07
Aug 13, 2015 06:15 PM
mizz0313
Aug 12, 2015 06:45 AM
