305 to...327???
Old Jan 8, 2008 | 05:27 PM
GraveDigger's Avatar
Car: 1989 iroc
Engine: 5.0
Transmission: t-5
305 to...327???
so i know there is a big debate beteen the whole 305 and 350 thing, but i was thinking what if i went 327? im sure there are a few people who have done it, is it better than a 350? i know the more discplacement the better but everyone has a 350, how many people can honestly say they have a 327 under the hood, just thought i would throw it out there and see what everyone had to say about it...
Old Jan 8, 2008 | 05:39 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 305 to...327???
This has been discussed many times. A 327 generally means that you will be faster than a 305 and slower than a 350 with similar setups on each engine.
There is a good reason that Chevy phased out the 327 for the 350...
Old Jan 8, 2008 | 06:42 PM
Re: 305 to...327???
Think of a 327 as a 350 with ¼" of its stroke taken out.
Think of a 383 as a 350 with ¼" of extra stroke added.
Which will go faster?
Which one do people generally do, as an upgrade?
Could there be a reason?
What do you think will happen to YOU if you perform this downgrade? Are you different from everybody else in the world?
Old Jan 9, 2008 | 11:41 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 305 to...327???
The main key point to sofa's advice there - You can't turn a 305 into a 327. You can turn a 350 into either a 327 or 383, with basically the same dollars (you have to buy a new crank). There's your answer - why pay to DOWNGRADE when you can pay the SAME TO UPGRADE ?
You can however turn a 305 into a 335, but that's kinda the worst of both worlds (not a great idea).
Old Jan 9, 2008 | 11:44 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: 305 to...327???
you can buy a 383 kit for about $800. cheaper if you do some real good shopping.
Old Jan 9, 2008 | 04:24 PM
Car: 1989 iroc
Engine: 5.0
Transmission: t-5
Re: 305 to...327???
thanks for the replies, i guess would be a downgrade but what about a 427 haha
Old Jan 9, 2008 | 05:32 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: 305 to...327???
I am a big fan of the "no replacement for displacement," theory.
Go for it, use a 400 2 bolt block with splayed main caps for the center 3.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
