caddy swapage; wieghts and dimensions
Old Jan 11, 2008 | 05:18 PM
faytmorgan's Avatar
I have a Cadillac 500 all built all i want to know is the dimensions of the 82 to 92 Camaro /bird (v8). the length being the measurement from firewall to radiator /electric fan. and the width being from shock tower to shock tower.
lastly which weighed less the 3rd gen v8 bird or v8 camaro?
fayt-
pictures to come my camera is shot thanks to me girlfriend.
(ie 500 bored .30 over forged pistons 625 cam roller lifters rockers ported polished heads and possible i am going to use a m90 blower with a intercooler all custom also a aluminum intake which makes the motor weigh only 40 lbs more than a stock iron small block chev 305 ect.)
Old Jan 11, 2008 | 05:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: caddy swapage; wieghts and dimensions
Chances are you are going to need to delete the a/c to get it to fit, possibly the wiper motor. Im sure you'll have more than enough room front to back and side to side, its just going to come down to what accessories you can retain.
You may also want to go ahead and toss the idea of that M90 out the window, its just not going to be able to feed an engine that large.
Old Jan 11, 2008 | 06:05 PM
faytmorgan's Avatar
well i am going to run electric fans electric water pump. the only things on the engine are going to be power steering and the alternator. nothing else.
i just need the exact dimensions if possible and if anyone knows which of the who weighs less. which ever weighs less is the one i am going to go for i care less for looks. albeit i really like the predator kit.
"http://bageco.com/mckkits/mckkits_ponti.htm"
as far as the blower goes its not just a stock blower its setup as far as ported and the whatnot its not going to push ALOT of air but just enough for what i am looking for. i have not yet figured how i am goign to setup the carb for it yet blow through obviously but demon has a carb as such but is around 1500 bucks just for the carb . which is, well nuts.
Old Jan 12, 2008 | 05:11 PM
faytmorgan's Avatar
This IS a third gen site correct? so does anyone know the dimensions of their engine bay?
Old Jan 12, 2008 | 05:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it IS a thirdgen site, though i have had no reason to measure my engine bay, and few people are going to have that info on hand, nor are they going to just drop everything and run right outside and grab those measurements in the past 24 hours.
As for weight, it also depends on model, but in general the transams/gta's were the heavyest. A SC camaro or base bird will be the lightest
5 seconds of search
https://www.thirdgen.org/forums/engi...?highlight=500
i guess i can grab a measurement or two since im such a nice guy, you can send me some beer later
from right behind the dizzy, i have about 34" to the fan area
from the firewall overtop of the "frame rails" to the fans i have 32"
the width of the towers at its closest point is about 35"
the width between the "framerails" is about 30"
Old Jan 12, 2008 | 05:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't you own a measuring tape?
I won't say any more because all the info you need to know is in the above link.
Old Jan 12, 2008 | 09:07 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Who needs measurements??
I'd be more concerned with the precision hood cutting!!
Attached Thumbnails caddy swapage; wieghts and dimensions-cadmaropictures001.jpg   caddy swapage; wieghts and dimensions-cadmaropictures002.jpg   caddy swapage; wieghts and dimensions-cadmaropictures003.jpg
Old Jan 12, 2008 | 09:10 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Here's some more from guy who did it. I kept his pictures...
If you search Cadillac, I'm sure you'll find it.
Attached Thumbnails caddy swapage; wieghts and dimensions-cadmaropictures004.jpg   caddy swapage; wieghts and dimensions-cadmaropictures005.jpg   caddy swapage; wieghts and dimensions-cadmaropictures007.jpg
ex-x-fire
Jan 12, 2024 01:58 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
new87
Jan 9, 2005 08:33 PM
Homer
Aug 28, 2001 11:03 PM
shaocaholica
Aug 4, 2001 07:41 PM
