355 build help
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
355 build help
im seeking advice on my first sbc build on my own.
im starting with a 010 4-bolt main block that has been .030 over and new cam bearing installed. i have a GM forged steel crank, some sort of stock GM rods w/ arp bolts and forged flat top pistons.
first id like to say that id like to keep this a pump gas motor. that is my only stipulation. 93 octane. but id like to build it as hot as i can within a reasonable budget.
what do you suggest for heads? i was leaning towards some sort of aluminum heads.
best bang for the buck?
what do you suggest for a cam? i was thinking a mean solid roller.
now about the rotating assembally... should i go with a different setup than i have? maybe better rods?
how limited am i seeing how id like to keep the crank.
thanks...
-Jeff
thanks...
-Jeff
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Re: 355 build help
Theres alot of good aluminum heads out there but they are all more expensive then iron heads. i've heard some good things about Jegs brand aluminum heads, as they have good flow numbers, big valves, and are reasonably priced. i plan on putting a set on my 383 stroker in the future. you want everything to work together. what are your plans for the engine? drag only, street strip, road course? you want it to perform for your intended use, but not be overkill. i would suggest a modest hydraulic roller cam, no frequent valve adjustment needed and still makes very good power and reduces friction. something like a comp cams xtreme energy hyd roller 282 would work well.
Transmission: 4L80E/4L80E
Hard to beat this in the bang-for-buck category http://www.sdparts.com/catalog/engin...rHeadKits.aspx
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
Re: 355 build help
it would be a drag engine, with limited street use. id like to spray it also.
What induction were you planning on using?
Last edited by daturbosix; Jan 28, 2008 at 09:19 AM. Reason: Automerged Doublepost
Car: 86 camaro sport coupe
Engine: 355
Re: 355 build help
Can't argue with the vortecs for bang for the buck. Edelbrock E-tec 170's are also a good value if your dead set on aluminum. Hydraulic roller is also a freat choice but can depend on what you mean buy "budget".
A Super Victor is a serious manifold for a serious engine. No guts below 3500 RPMs, you'd better build a pretty stout rotating assembly and valvetrain for 8000 RPMs.
Let's talk budget - you have $10k to spend on this or not?
Re: 355 build help
Not sure on your budget but if you're looking for a good bang for your buck check into the 062 Vortec heads they can be had from several places here's something to consider also:
http://www.sdparts.com/product/SD806...RPMAirGap.aspx
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
Re: 355 build help
well i aquired this short block from a family friend. and no, im not looking to dump 10k into it. i need a valvetrain and heads to make it complete, but i was hoping to go 10.90s on nuts, and then be able to take a 100-150hp shot.
it will probably be going into a fox chassis.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Billy Decker
Sep 4, 2015 03:46 PM
