wat kind of heads should i use on a 350 bored .30 over
Old Mar 23, 2008 | 09:11 PM
black1990RS's Avatar
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
i have a 350 4 bolt main block and wanna see wat kind of heads to use,,,i have a set of camelbacks but i have been told they are not as good as aluminum vortecs. any advice?
Old Mar 23, 2008 | 10:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: wat kind of heads should i use on a 350 bored .30 over
what power do you want to make? Choose the head you can afford thats gonna meet your goals. Any factory Iron head except for vortecs are pretty much junk. Best iron heads that have some potential are L98 083's. Vortecs are great heads tho for many builds
L98 aluminums arent that much better out the box than the iron cousins. Ported they are nice tho
Old Mar 23, 2008 | 10:19 PM
88ZNX's Avatar
Car: 1988 Camaro IROC Z
Engine: Buick 3.8 V6 turbo
Transmission: th400 with TB
Axle/Gears: Mosser 9" 3.50 9.44@146.7
+1 for the Vortec heads. they are awesome.
If you can swing for aluminum, AFR and Canfield work awesome. The AFR 190cc and 195cc are about as big as I'd go on a 355ci. They make great power for a TPI.
Old Mar 23, 2008 | 10:34 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
patriot cylinder heads make a low priced aluminium vortec style head. i think it is patriotperformance.com
Old Mar 23, 2008 | 10:56 PM
Car: 1990 camaro RS
i am lookin to push out alot of power but not the gas mileage, i want it to stay fairly good. but i have a perfect TPI system to help with that.
Old Mar 24, 2008 | 08:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If you want to be pushing much HP you won't be using the TPI system anymore. Plan on upgrading to mini-ram or the like.
How much you wanna spend? Aluminum canfields or patriots are awesome, but I hope you have $1200 burning a hole in your wallet.
Old Mar 24, 2008 | 10:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yep stock TPI is not gonna get it done but then again how much is alot of power? To me thats near 400 to the wheels. Some ppl may think 400 on the motor at the flywheel is alot.
Old Mar 25, 2008 | 12:10 AM
Car: 1990 camaro RS
well i dont know about 400 hp i am only 16 i dont think i could handle that,i have the 350 block bored .30 over with flat top pistons, a comp cams medium cam, and a set of camel backs that need a vavle job and the polished and painted TPI with a brand new fuel rail and throttle body.and other little things like valve covers and timing chain cover i am just not sure about the heads,should i redo the camelbacks or find good not to exspensive aluminum heads.
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
neekolzun
Aug 24, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
89-S-dime
Aug 12, 2015 11:57 AM
