PLEASE HELP!!!! I HAVE A 91 CAMARO 350CI NEEDS MOTOR!!!!
Old Apr 6, 2008 | 01:13 AM
TURBO F100's Avatar
Well here is my problem I bought a 1991 that I was going to fix up It did not start and the starter was jamed so I took a look under the car and I saw no signs of any major damage so I bought it well when I removed the starter I found a out ward den in the oil pan and a hole well the motor threw a rod (so much for people being honest when selling something, the guy said he parked it running, right sure you did)
Anyways here is my question a friend of mine has a 350 that has been freshly rebuilt and has a xe265h comp cams and the heads have been pocket ported, the only thing is that the heads are the carb stile heads, I was wondering if I could still use the older heads with my tpi intake, I herd that you could but you would have to drill out the intake manifold holes to bolt it down??
I also have a sb 400ci that I could rebuild and use or could I ??
What would be a better choice ??
Help with this would be great!!!! and any other problems I might encounter when I try to do this.
THANKS!!!!
Old Apr 6, 2008 | 01:17 AM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: PLEASE HELP!!!! I HAVE A 91 CAMARO 350CI NEEDS MOTOR!!!!
is this a tbi camaro or a tpi?
Old Apr 6, 2008 | 01:18 AM
Car: 91 maro
doh/u will need help with puter.it will run tho,not right but it will
Old Apr 6, 2008 | 02:38 AM
TURBO F100's Avatar
It is a z28 so tpi 350ci, I was thinking of going with "pcm for less" for the tuning job, are they good???
What about the tpi intake to the older carb heads? what mods do I need to do to the tpi intake manifold to make it work with the carb heads???
THANKS!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
slade5612
Aug 11, 2015 07:19 PM
Elliswon
Aug 10, 2015 12:33 PM
92projectcamaro
Aug 6, 2015 01:20 PM
