stock 305 beef up...
Old Apr 7, 2008 | 07:12 PM
cakespat's Avatar
I have an 83 Pontiac T/A, stock 305, 5 speed, 140,000 miles. I'm doing a paint job and want to beef up the motor. Im deffinetly going to pull all the emissions crap off the car. Any good cheap ideas?
Old Apr 7, 2008 | 10:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Do you have the LG4 carb, or cross-fire 305? Makes a little difference.
Check out the FAQ forum for a thread that talks about the differences between 305's and performance upgrades.
Careful what you call "crap". If you have a carb, the computer controlled unit is very capable of performance, driveability, and economy, out-distancing the non-computer versions in every category.
If you have CFI, you have a little more work ahead of you.
Old Apr 8, 2008 | 04:18 PM
cakespat's Avatar
Re: stock 305 beef up...
it has the cross fire carb.
Old Apr 8, 2008 | 04:26 PM
five7kid's Avatar
That would be cross fire injection, which is two throttle body injectors. Looks a little like carb, but isn't.
There really isn't much performance support for that system. A carb conversion may be your best bet. You need to look over the EFI to carb tech article linked from the thirdgen.org homepage, and the FAQ thread I already mentioned. A Holley 600 double pumper is what you should be considering, since you have a 5-speed.
Old Apr 8, 2008 | 04:30 PM
cakespat's Avatar
ok i just took a look at it, its not the cross fire its the lg4.
Old Apr 8, 2008 | 05:02 PM
five7kid's Avatar
Okay, follow the FAQ thread recommendations for performance upgrades.
Old Apr 8, 2008 | 07:23 PM
cakespat's Avatar
haha, i sound like an average ****ing chump, wait maybe i am... thanks for your help bro
Old Apr 12, 2008 | 11:20 PM
enoughtraction's Avatar
Car: '86 v8 sport coupe hatchback
Engine: 305CI
Axle/Gears: stock... looking for low gear posi
Try to find a quadrajet to swap on,if its not injection remove all emissions equipment, a good muffler and an air cleaner for a 350, you can easily make some cheap power like that just try to get more air in and more exhaust out, I haven't dyno tested it but on my 86 w/ weird computer controlled quadrajet by adding a 350 air cleaner magnaflow muffler removing the cat and disconnecting the smog pump it really felt like it opened the car up allot if you want to invest a little more id imagine the stock smog-tastic exhaust manifolds are very low performance, you could replace with headers or non smog manifolds very cheap if you hunt around for used parts. for about $20 you can get an exhaust cutout and put it after your Y pipe to open up to straight pipes when the cops aren't listening.
basicly because you want to do it on the cheap said your best bets are playing with the air intake and exhaust IMO
Old Apr 14, 2008 | 05:23 AM
Bad5OGT's Avatar
Car: 1986 Ford Mustang GT
Engine: 5.0
Vortec heads, CompCam XE274-H cam, Performer RPM Vortec Intake, 650/700cfm carb, headers, cat back and you are bumpin' 300hp.
Old Apr 14, 2008 | 01:41 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
The 305 is already low compression... vortec heads would drop it even further. I would try a good flowed set of 58cc heads, but other than that i have to agree with the last post. 300hp would be very possible.
Old Apr 15, 2008 | 02:32 PM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Geez, just that little bit of stuff could bump an LG4 to 300hp? What about an LO3, or should I just give up and get a 350?
Old Apr 15, 2008 | 04:31 PM
Bad5OGT's Avatar
Engine: 5.0
Yes it does, but that's at the crank not wheels and the max hp will be roughly in the mid - high 5000rpm range.
Old Apr 18, 2008 | 01:15 AM
Engine: 305CI
you could get a nos sniper setup and add 75hp lol =P
Grant2k
Jul 10, 2018 04:01 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
marcusaw
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 8, 2015 01:18 AM
Leggman1
Aug 6, 2015 04:15 AM
